To Be Honest!GSX1400 wrote:I think there must also be a difference between Chinese and Corean.
Hyundai/Kia/Daewoo have good cars. They're Corean if I'm not mistaken?
They seem to be the "new" japanese.
What does "tbh" mean in your text above?
The simple fact is, engines only wear when the moving bits touch and the moving bits only touch when the oil film between them fails. The oil film fails due to heat and that happens during cold starts when the oil is too thick so can't flow past the hot bits fast enough, and also if the engine is overheated and is simply too hot for the oil to cope. Most engines wear out due to the cold start bit.
your Daelim will probably be able to do twice the distance it has already done because it is doing very few cold miles compared to 'hot' miles and never gets pushed hard enough to get overly hot.
