RIDERS CUB DISCUSSION
gtd65
Re: RIDERS CUB DISCUSSION
Post by gtd65 » Fri May 12, 2023 3:35 pm
Well it turns out the replacement battery was defective and dropped down to 11.1v after one week sitting in the house.
They are sending out a replacement unit, so that's decent customer service.
The speedo drive gear must be slightly out of tolerance (not a close enough fit) as I can get the drive to work fine when it's first installed but then it loses drive. I can only imagine that the worm gear is moving away from the drive gear?
Is it just the philips screw that holds the speedo cable and worm gear in place or is something else meant to stop any lateral movement?
Post by bikerbaker » Fri May 12, 2023 5:57 pm
I'm no help, I've never detached the cable on mine and had never noticed the Philips screw, I've had the front wheels out on both bikes too.
I'm a fan of Motobatts, they seem to hold a charge for longer, I use one of them to power the pump in my camping kitchen. Must remember to check it out soon though. :D
gtd65
Post by gtd65 » Fri May 12, 2023 11:35 pm
I'm not sure why my original speedo gear got so badly chewed up, can only assume that there was no lubricant installed at the factory?
I took some measurements of the speedo gear and it showed 33mm but all of the replacements seem to be 32mm across the geared area.
I'm trying to recall if there should be a, bung, to keep the worm gear in place. For some reason, that's way back amongst the cobwebs of my brain but can't recall clearly whether or not it's a false memory :lol:
gtd65
Post by gtd65 » Fri May 12, 2023 11:53 pm
Not the same machine but a very similar setup, I'm fairly sure I'm missing the bung or whatever you call the ring that holds the worm gear in position.
https://www.youtube.com/watch?v=ZBFP35m_x2E
gtd65
Post by gtd65 » Mon May 15, 2023 12:16 am
It looks like what I'm missing is a speedo "pinion bushing"?
You can see an example in this video with a CG125...
https://www.youtube.com/watch?v=NNx5jRke0f4
Post by bikerbaker » Mon May 15, 2023 4:57 pm
I blame you!
Went out on the Wave yesterday and the speedo stopped working. No screw to hold the cable in but there is a plastic clip on the outer to locate it which had broken. One very chewed up drive gear, new one ordered and will hopefully fix it, if its the worm then that's £110. At least the bits are still available from Honda.
gtd65
Post by gtd65 » Mon May 15, 2023 5:09 pm
If you need to replace the worm gear, I'll send you a link to get one complete set for under £3 delivered. 😉👍
Post by bikerbaker » Mon May 15, 2023 5:56 pm
Thanks, I'll let you know. I'm hoping the drive gear will fix it, fingers crossed.
gtd65
Post by gtd65 » Mon May 15, 2023 6:26 pm
Fingers crossed it goes to plan!
If you happen to know of any old knackered brake hubs with a pinion bushing in it, you know where I am! 🤣
I have a spare pinion that's too narrow for the super cub, if you need a new one and it's the same measurements as yours, I'll send you mine.
gtd65
Post by gtd65 » Thu Aug 17, 2023 12:21 am
I finally got some pics of the part that I'm missing - the bushing that holds the pinion in place.
I knew I was not making up a memory of a silver bushing.
The main question is, where to source the bushing?
