2006 CG125 Centre stand/side stand
knapdog
Post by knapdog » Thu Apr 04, 2013 4:09 pm
Tried to get centre stand off today to repaint but couldn't get it off. Looks as if it has rusted solid to centre spindle that also incorporates the rear brake pedal. Apparently it is a common problem. The brake pedal works freely but every time you use the stand you can see the spindle rotate which, I guess, will eventually make the hole in the frame larger. I've given it a few good whacks to try to remove it but I'm afraid of damaging the frame lugs.
What would you do?
Or should I paint it in situ, leave it and never use it again or buy this:
http://pages.ebay.com/link/?nav=item.vi ... 0484116798
barker
Re: 2006 CG125 Centre stand/side stand
Post by barker » Thu Apr 04, 2013 5:05 pm
it will bug you so in the end you will just have to get it freed off i lasted 6 monthes then i had to sort it out
knapdog
Post by knapdog » Thu Apr 04, 2013 6:34 pm
barker wrote:it will bug you so in the end you will just have to get it freed off i lasted 6 monthes then i had to sort it out
Thanks, but what did you actually do?
Any thoughts on that ebay side stand?
barker
Post by barker » Thu Apr 04, 2013 11:26 pm
lods of us have done this job wait till awarm day lay the bike onits side get a thin cutting disc annd cut the pin either side of the frame take out pin cut length ways olong the stand were the pin goes thro this will release the pressure on the pin it will now knock out get new pin grease it weld up the long cut in the stand and refit,
billyfix
Rides:: c90 6v classic, c90 cub economy, Triumph Bonneville T120. mk 2 Honda cbf1000 FA
Post by billyfix » Fri Apr 05, 2013 8:17 am
This is exactly what i have just done to my recent c90,the bonus is i closed the small cut by squeezing in the vice,welded it,and now the new greased pin is a nice tight fit.
knapdog
Post by knapdog » Fri Apr 05, 2013 10:13 am
billyfix wrote:This is exactly what i have just done to my recent c90,the bonus is i closed the small cut by squeezing in the vice,welded it,and now the new greased pin is a nice tight fit.
BRILLIANT!!!!!!
YOU CAN DO MINE AS WELL!
knapdog
Post by knapdog » Mon Apr 08, 2013 1:44 pm
Would the slit HAVE to be welded? What about a thin slick of silicone? Enough for the stand to still move freely but also enough to keep the water out. Surely with a thin cut there would be enough inherent strength left in the stand ( particularly if the gap was squeezed in the vice ) so as not to compromise its safety. Or am I completely barking up the wrong tree? When you don't have welding access you have to think of everything!!!
Boo
Post by Boo » Mon Apr 08, 2013 2:47 pm
knapdog wrote: When you don't have welding access you have to think of everything!!!
Jubilee clips. :)
billyfix
Post by billyfix » Tue Apr 09, 2013 10:04 am
Blue tack? :lol: :lol: :lol: just get the stand off and i will weld it for you,stop being such a drama queen. :roll:
knapdog
Post by knapdog » Tue Apr 09, 2013 11:47 am
billyfix wrote:Blue tack? :lol: :lol: :lol: just get the stand off and i will weld it for you,stop being such a drama queen. :roll:
When I find myself in times of trouble
Brother Hairy comes to me
Speaking words of wisdom
Let it be!
