points plug and valve gaps 1973 c50 any one know??
- Rides:: Honda C50, C70, C90
need to get the gaps for points plug and valves if any one can help me?
- Boo
- Rides:: Elephant Grey 1967 CM90 based 'bitsa'.
Re: points plug and valve gaps 1973 c50 any one know??
Points gap 0.3 - 0.4mm (set so they open exactly on the 'T' flywheel mark)
Plug gap (preferably an NGK) 0.6 - 0.7mm
Valve clearances 0.05mm, set cold, inlet & exhaust.
thanks a lot also does anyone know where I can get new points from all the ones I try to buy on eBay only go from 75 on mine is a 73 I do not know much about these c50s I'm new to it allBoo wrote:Points gap 0.3 - 0.4mm (set so they open exactly on the 'T' flywheel mark)
- cruncherkid
- Rides:: CD175
Hi Jim, the 1975 date given by some ebay people is a bit mythical as there weren't any model changes that year....1975 points will fit a 1973 modeljimfritz59 wrote:......does anyone know where I can get new points from all the ones I try to buy on eBay only go from 75 on mine is a 73......
thanks a lot i will have a look at all the parts they do !!wightegi wrote:Check out this page http://www.wemoto.com/bikes/honda/c_50/75-78/
