Hello Everyone
chris2004
Hello Everyone
Post by chris2004 » Thu Dec 08, 2011 10:43 pm
Hello,
I have a question based on a 1983 model Honda atc 110 I know this is the C90 forum but I hope you dont mind me asking some questions.
I have bought a 1983 honda atc 110 but the previous owner has all missed matched parts on the engine,
The head of the engine has the front mount which seems to be original but the block of the engine has C90E stamped on it.
The thing is the block has the original alternator still fitted with the neutral switch behind it but it does not seem to match up with the ignition coil and the flywheel center bolt has been snapped off ( its a bit of a mess ).
I have seen some lifan engines for sale and was wondering is it possible to fit these to a atc 110?
Many Thanks
Chris
dread
Rides:: lamb chop, vespa cutdown. italjet dragster chopper
Re: Hello Everyone
Post by dread » Thu Dec 08, 2011 11:11 pm
atc 3 wheeler or the ct110 posty http://www.google.co.uk/search?hl=en&cp ... 36&bih=428 cause we love ct's want one please st nich :lol:
chris2004
Re: Hello Everyone
Post by chris2004 » Thu Dec 08, 2011 11:22 pm
Hi Dread,
Thanks for the reply,
Its the ATC 3 wheeler.
cruncherkid
Rides:: CD175
Re: Hello Everyone
Post by cruncherkid » Fri Dec 09, 2011 6:49 am
Hi Chris, welcome to the club! Sounds like somebody has chucked a 6V C90 bottom end into the bike, is there a capacity cast onto the cylinder barrel to show engine size? I know the ATC110 and 6V C90 engines are mechanical cousins....the C90 is 3 speed and the 110 is 4 speed, how many gears can you select? I think that's a good starting point to get you some answers....
Tons of expertise on here from the other guys about shoe-horning other engines in, and the bracketry required for conversion from this particular shaped engine to the cub/pit shape :) Sounds like a fun project....
cruncherkid
Rides:: CD175
Re: Hello Everyone
Post by cruncherkid » Fri Dec 09, 2011 8:46 am
chris2004 wrote:.......The head of the engine has the front mount which seems to be original .........
To add to my above reply.....after a quick study the ATC110 is a slightly longer stroke, so i would bet you have an 89cc cylinder on it if your engine number is C90E-XXXXXXX......the front mounting lug is only cast onto the engine top cover, so could easily be swapped onto a 90cc engine....
Does your engine have a kickstart shaft? An ATC engine wouldn't have one, and would have a ripcord/pullstart mechanism on the left hand side........
chris2004
Re: Hello Everyone
Post by chris2004 » Fri Dec 09, 2011 12:21 pm
Hi Cruncherkid,
The engine that has been fitted to the atc does have a kick start which has to be pulled upwards by hand as there is no room to kick backwards with the back wheel.
This is whats making me think is it worth spending money trying to get this engine running (and still have a bad job at the end)
Or should I try and fit a lifan 125cc with electric star and manual clutch, if possible.
Regards
Chris
cruncherkid
Rides:: CD175
Re: Hello Everyone
Post by cruncherkid » Sat Dec 10, 2011 7:53 am
Sounds like a Lifan might be the least hassle way to go.....you'll have to bracket the engine though to convert the mountings, been some recent posts about that, and not a conversion i have done myself. Have an ask in the engine section, and you will get some expert replies from the other lads for sure :) Electrics for these engines are well covered too, shouldn't be any hassle as an offroader will only need minimal loom......all the knowledge and help is here :D
chris2004
Re: Hello Everyone
Post by chris2004 » Sun Dec 11, 2011 1:28 am
Hi Cruncherkid,
Thanks for your help
I will give the engine section a try
Regards
Chris
