Hello folks, recently picked up TWO!!!(not one), Honda CT90s that arrived in a box of bits from the States. The guts of the engines are pretty much toast. Would need rejugging, valves are corroded to the seats etc. I will like put a Lifan or similar engine in, is that sacrilege around here ?
If anyone has any Lifan motors they want rid of? And a better method of getting the rear mount to line up without a janky looking rear motor mount then direct me to the thread.
Barley
Honore De Balzac
Re: Honore De Balzac
Second-hand Lifans make good door stops. The mounting bracket is not really seen under the engine so works well. Dr ATV in America was the go-to person for the brackets.
