Forks /front wheel.
Daz3226
Rides:: 1997 c90
Forks /front wheel.
Post by Daz3226 » Mon Feb 19, 2024 8:53 pm
Hi all,first time poster .
I have inherited a c90 ,2001.
The front end is damaged ,can I replace the forks with a set from a 1997 c90 ?
Thanks in advance for any help .
Re: Forks /front wheel.
Post by wightegi » Mon Feb 19, 2024 10:34 pm
Hi the forks should be fine, there were not many changes to the 12 volt bikes in that area.
Devon general andy
Post by Devon general andy » Tue Feb 20, 2024 6:33 am
Just adding and confirming wightegi’s reply:-
Yes, yes….. 1997 (P / T ) forks will go straight into a 2001 (T). You have ‘O’ rings on the bottom arm links and NO NIPPLES!!
Hope this helps,
Andy.
Daz3226
Rides:: 1997 c90
Post by Daz3226 » Tue Feb 20, 2024 3:44 pm
