Howdy from the states!
Leiba
Rides:: Red C90.
Re: Howdy from the states!
Post by Leiba » Tue Mar 14, 2023 12:03 am
6V. then the gear change is likely to be 1 forward = 1st, 2 back ( or toe up) = 2nd, and back again for 3rd.
Anywhere near Malta or Dekalb?
Maddragoon
Rides:: 1968 CM90, TaoTao 50
Post by Maddragoon » Tue Mar 14, 2023 12:43 am
Couple hundred miles south east of DeKalb
Maddragoon
Post by Maddragoon » Thu Mar 16, 2023 4:00 am
I did the clutch test you guys were talking about today. When I push into 1st gear and hold it the wheel engages so I guess I need to make some adjustments. It does it in every gear too by the way. I don't know if that would make any difference but I thought I'd throw it out there. Lol
The way it jerks when it shifts makes me think the clutch is disengaging at all. If I sit idle in 1st gear though it doesn't fight to move unless i apply throttle. If I idle try in 2nd or 3rd it seems ok too but if I apply throttle it bogs down. So the CVT is working to some extent right?
JohnS
Rides:: .2019 Honda C125
Post by JohnS » Thu Mar 16, 2023 11:02 am
Everything you are saying says the clutch needs adjusting.There are 2 clutches on the bike,a centrifugal one,controlled by engine speed ,and a manual one,controlled by the first movement of the gear lever.Adjusting the clutch only affects the manual one.
I’m sorry but it’s been so long since I did adjust a clutch,I can’t remember which way you should turn it,I think some manuals state the wrong way.
I’m sure someone will tell you the correct method.
Maddragoon
Post by Maddragoon » Fri Mar 17, 2023 12:12 am
Well let's hope someone does because I have no clue where to start 😅
JohnS
Post by JohnS » Fri Mar 17, 2023 10:42 am
I know how to do it,but not 100% sure which way to turn the adjuster,but you could try it both ways until it works.
Sorry I only have a photo of my C125,but yours should be very similar.
The adjuster is below and slightly to the right of the oil dip stick,the one with the lock nut on.
Release the lock nut and unscrew the adjuster slightly.Then screw the adjuster in gently until you feel some resistance.Then (this is the bit I’m not 100% sure of) unscrew the adjuster a quarter of a turn.Now tighten the locknut up being very careful not to move the adjuster.That should be it,fingers crossed.
JohnS
Post by JohnS » Fri Mar 17, 2023 10:49 am
Just come across this photo on Facebook,may be more like yours.
The adjuster is in the middle of that circle on the engine cover.
Maddragoon
Post by Maddragoon » Fri Mar 17, 2023 11:42 am
Sweet! Thanks JohnS
nabs
Rides:: c90 z2 (1978)
Post by nabs » Fri Mar 17, 2023 12:21 pm
here are Honda's instructions for adjusting the type of automatic clutch installed on the CM90
JohnS
Post by JohnS » Fri Mar 17, 2023 2:45 pm
That’s brilliant nabs
