New Member - C90zz 1979 - Paris
Posted: Sun Jan 28, 2018 11:35 am
Hello gang,
Been trawling through the club threads for
The last month or so - endless help getting my (not so) new (Blue) 1979 c90zz going again! Carb cleaned and oil change as well as a change up of the fuel lines, a new filter, battery and the old girl is running like a dream(ish).
I've just imported one of My dads old 1979 c90s from the uk over to France.. Bit of a nightmare changing over the documentation but nearly there. Shoot me a message if anyone needs any help getting that kind of paperwork sorted - I can send you in the right direction.
I only have one issue with my cub not sure if it's a problem or not really - she cuts out when I fully disengage the choke - regardless of weather or revs. It only runs when the choke is a engaged let's say 1/4 - it cuts out any less thank that. The carb surely doesent belong to the c90 as its a manual choke and the airbox fitted isn't like any I've seen on the forum,
Although it is a keihan. I've checked for air leaks on the manifold and it seems sealed up - it smells to be running a little rich but it's ok!
Any ideas?
Happy riding! Any other members in Paris give me a shout!
Any ideas?
