Hi,
I am Mariano from Argentina, recently I have bought an old C90.
I like to repair and restore things, this might be some fun for me.
I hope this forum can help me with information and tips / hints with the process.
first question: what year / model is this C90?
Hi I am Mariano from Argentina
- Rides:: C90
Re: Hi I am Mariano from Argentina
Hi mario and welcome to the forum.
Your bike is not a version that would have been available in Europe, it has a separate fuel tank bolted to the frame which would usually denote a 6v electrical system and contact breaker points ignition system on the engine - however your engine appears to be a CDI motor.
I know some South American versions had a 6v CDI motor - how many cells does the battery have?
If I was to guess I’d say your bike dates from 1976/77 as the keyswitch position would indicate a ‘ZZ’ Type model, does it also have the rotational gearbox so you can go from 3rd gear to neutral when stopped?
- knapdog
Nice one Dave.
Welcome Marianos.
Welcome Marianos.
- Rides:: C90
yes it's a 6 volt system and yes it's a 3 gear rotational gearbox.
the motor number is : C90E-2008123
