hi from Sussex
- Rides:: Honda innova
hi from Sussex
Hi,
I have been a member for a while as i had a innova a while ago, i have just recently got a 82 6 volt c 70 cub. She's not well so hopefully will get to the bottom of it.. anyway just re introducing myself to like minded folk..
Re: hi from Sussex
welcome what's up with your cub, were abouts are you in sx as there's a member in bton and another in Littlehampton
Re: hi from Sussex
thanks for the welcome! it starts but is very rich, i have not been through it but a very good mechanic has looked at it and has installed a new set of points, checked the gap and timing, new carb, valve clearances done, battery seems charged, (not tested but loud horn and bright neutral switch) fuel seems fresh but can't verify. but intermittently it sounds like the choke is on and chugs the plug is black as your hat. very odd mainly it runs rough, its done just under 10k 1982 c70 with round headlight can't really tell you any more i need to go through it all for piece of mind, maybe if someone is near me they can cast their eye over it.. cup a tea always on the go .
Re: hi from Sussex
All I can say is what I was told I also have the old carb as the problem was thought to lye with that but it wasn't, the new carb looks like an exact replica no branding, I need to check jet size to, the needle clip is in the middle, mixture screw x2 turn out from lightly seated it has a round fuel bowl, I think it's better zz model as it has no small light under the headlight
Re: hi from Sussex
Wicked! I saw three 90s up whiteways about a month ago spoke to the blokes up there they were nice chaps
Re: hi from Sussex
was,nt me then ,, were are you one of us may pop round to give you sympathy and mainly drink tea I don't take sugar
Re: hi from Sussex
Excellent neither do I! I am in Westergate your welcome round for a cuppa and a squint only quickly spent an hour on it so far checking bits but it's got me foxed at the moment, I need to start again and look at it. Thanks for all your messages
Re: hi from Sussex
just a thought take the exhaust off and see if it runs then if it does fit a new one as yours is blocked or restricted
