Hello everyone my first C90
C901987
Rides:: KTM 950 adventure S 2005, Honda C90 1987
Re: Hello everyone my first C90
Post by C901987 » Sun Jul 23, 2017 6:58 pm
wightegi wrote:
Sun Jul 23, 2017 11:38 am
If you are finding it difficult to change gear the clutch needs adjusting ;) .
The lever is also the clutch pedal so wind the revs off ,push down all the way and bring the revs back on as you release the pedal.
If the bike wants to pull away with the pedal all the way down in first it is the clutch.
Hey thanks for the help i have adjusted to clutch after a some monkey had jammed to inner to the outer nut and it is much better, different bike now. I had a new issue today when i had the missus on the back (she is only 8st). The rear wheel is off center and rubs on the inner arch causing the tyre to melt i have "adjusted" the inner arch so that it isnt as bad now, but i want to resolve it. The rear wheel is free running no binding at all im wondering if the spacers that have been used are wrong for the year or what ever, or is this normal? (cant be?). I think the Myford ml7 might help here, i might turn up some new spacers or buy them depening on cost /time saving.
thanks everyone for being so welcoming i dont think there is a forum out there that is so friendly. :P
Leiba
Rides:: Red C90.
Post by Leiba » Sun Jul 23, 2017 7:03 pm
There's marks either side of the swing arm where the axle goes through usually used for tightening the chain. Make sure they are both on the same notch.
Post by wightegi » Sun Jul 23, 2017 8:57 pm
Myford 8-) :D
If you look at the CMSNL site they have exploded diagrams of all the parts so you can see if anything is out of place.Google CMSNL classic motorcycle spares Netherlands ;)
A set of new shocks would help keep your rear end up :o :roll: :lol: :lol:
C901987
Post by C901987 » Mon Jul 24, 2017 9:36 pm
Myford 8-) :D
Hey thanks for the link! i have had the wheels off today and checked the diagram against what i have and its the same. The rear tyre was a 3.00 17 which didnt help at all i have new shoes on her now i went for some conti go's they seem good so far i have only taken it for a quick ride nearly had an off riding around a car on a slippy patch, i shall take it a bit easyer for a while just cant help zooming around with ease. The rear end seems fine with the new tyre now just a tad one sided?
Post by wightegi » Tue Jul 25, 2017 7:08 am
With a 300 tyre someone has been playing so other bits may have been modded to suit 2.50 is the standard size . Conti...not good in the wet ,the racers use Metzlers ;) .
