fitting a side stand
- Rides:: c90 cub
Hi there,I'm trying to fit a kick stand to my 1995 c90, can't see where it should go. Help appreciated. Andy
- Rides:: Red C90.
Re: fitting a side stand
If it didn't originally have one then the fitting for it won't be there.
You'll have to try and find a set of foot pegs with the stand already fitted.
Is yours a kick or leccy start bike?
- Rides:: c90 cub
leky. I dont know if it originally came with one. Did some models have both?
- Boo
Sidestands disappeared from UK Cubs in the early '90s thanks to health & safety legislation for new bikes..
An engine cut-out became required if you put it in gear with the stand down, so Honda just got rid of the stand.
You need a footrest bar from an earlier electric start version.
http://www.ebay.co.uk/itm/HONDA-CUB-C90 ... 359wt_1344
The kickstart-only model has a narrower engine case on the left, so it won't fit the leccy start engine.
- Rides:: Red C90.
It's nearly always leccy start sidestands you see on ebay. I've had a couple on my kickstart bikes, you just need to adjust the gear lever. (In my case I just bent it outwards a little)Boo wrote:
But you won't need to do that with your leccy bike.
