Exhaust collars
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
Exhaust collars
has anyone got a pair of exhaust collars for a 6 volt 50 or 70. A 6 volt 90 will NOT fit. i am willing to pay postage
Re: Exhaust collars
If you don't find any there easy enough to make but you need to know the diameter of the exhaust pipe they go around and the diameter of the hole in the head take one from the other less clearance then divide by 2 for the thickness them fit pipe and measure how wide
Bit of steel stock around a former (impact socket ) and
Dave
Dave
- krazy kev
- C90Club Clown!
Re: Exhaust collars
Great idea. if i remember they are about 2-3mm thick. i might be lazy a buy new ones. i have the part numberdavebike wrote:If you don't find any there easy enough to make but you need to know the diameter of the exhaust pipe they go around and the diameter of the hole in the head take one from the other less clearance then divide by 2 for the thickness them fit pipe and measure how wide
Dave
Re: Exhaust collars
I have only made them for c90zz and other bikes if I couldn't get them quickly and needed to finish a job !
It is not hard but if DS or similar have them
Dave
Dave
- krazy kev
- C90Club Clown!
Re: Exhaust collars
Hi Dave
i had the letter from you with the collets in. it was not the valve collets i needed, it was the collars for the exhaust that go around the tube of the downpipe to hold the exhaust against the head. they are around 1 inch across. let me know if you want the valve collets back. here is a picture of the exhaust. the collars are item 1
- steveST100
Re: Exhaust collars
Think i have a set of them somewhere in the garage, will have a look for them this afternoon.
- krazy kev
- C90Club Clown!
Re: Exhaust collars
Let me know the price. cheers matesteveST100 wrote:Think i have a set of them somewhere in the garage, will have a look for them this afternoon.
- steveST100
Re: Exhaust collars
Found 2 sets, just pm us your address and i will post one set to you.
- krazy kev
- C90Club Clown!
Re: Exhaust collars
pm sentsteveST100 wrote:Found 2 sets, just pm us your address and i will post one set to you.
- steveST100
Re: Exhaust collars
Should be in the post today.
