WTB 1977 c90 legshields and carb to air filter tube
horror
Rides:: honda cg 125 honda c 90 bsa b32
Post by horror » Sat Jan 16, 2010 2:55 pm
Hi there
I have this honda c 90 from 1977
I would like to buy a set of legshields
a carb to air filter connecting tube (fits cable choke carb)
also i need the small metal clip to hold the choke cable onto the carb and i need a carb needle retaining clip
if anyone has some send the message or easier just ring 07855509139
maxwell
matt.leese
Rides:: 1995 red 107cc c90, 1979 blue c70 zz, 1985 c90 cub blue, 1971 c50, 1973 c70z2
Re: WTB 1977 c90 legshields and carb to air filter tube
Post by matt.leese » Sat Jan 16, 2010 3:50 pm
the best place for the filter tube would be ww.cmsnl.com for a new one, or you may get a second hand one from the breakers yard or evilbay.
as for the legshield get it from wemoto they have the best ones for the 6v bikes, their not like the cheap white ones which dont fit correctly, they are nice mand thick and they are the origonal creamy colour, but the only thing is they dont say honda on them, i have bout quite a few of the cheap white legshield and they are shoocking! the ones from wemoto are the dogs danglies. :) and i think their around £30, you wont get any cheaper than this for a new one. ;)
horror
Post by horror » Sun Jan 17, 2010 2:53 am
Is it possible to fit the earlier leg shields and cut a hole in them for the ignition key?
I have the shields from this
it has the ignition in a different location.
i coud just try it but the bikes in suffolk and im in london at the moment. just whondered if somebody has tried this.
ill have a look. i have to mot it and i'm wondering weather having no plastic shields will sway the mot'er to fail the heap
matt.leese
Post by matt.leese » Sun Jan 17, 2010 10:58 am
horror wrote:Is it possible to fit the earlier leg shields and cut a hole in them for the ignition key?
my ignition is on the left hand side of the legshiled , it bolts to the top left of the centre tube. the legshield for this bike wemoto sell are the good ones , but the hole for the ignition will need ctting out, :) i dont think i does need the legshield fot the mot, look @ all the sreetfighters with no panels ! and these go through the mot. so i would say no it doesnt neeed one, and it dont need a chain gaurd either! :)
horror
Post by horror » Sun Jan 17, 2010 3:40 pm
Yea I suppose, I thought they may kick off about it. I also heard that if i tape off the indicators I won't need those to function either.
You have to cut the key hole out of the new shields you buy?
How do you position the hole in the correct place? I suppose I could just use the old shields from the brown one and cut the hole.
matt.leese
Post by matt.leese » Sun Jan 17, 2010 3:49 pm
horror wrote:Yea I suppose, I thought they may kick off about it. I also heard that if i tape off the indicators I won't need those to function either.
cut it with a plastic hole cutter at the right size. place your legshield on without the hole and mark with a pencil from the inside and you should get it right, make the hole 1-3mm bigger so have room to play :)
or of you dont want to cut a small hole in the legshield, you could always put the ingnition in the left hand side panal, all you will need to do it cut a hole in the sidepanel for the ignition or buy a side panel which already had the hole in it, :D
horror
Post by horror » Mon Jan 18, 2010 2:18 am
Ah cool, that may have saved me some loot.
I can choose from both options as i have the side pannel from the brown one with the ignition hole already ha ha
Boo
Post by Boo » Thu Jan 21, 2010 5:38 pm
Don't move your ignition switch! :o :o The front mounted switch on your C90ZZ is a different physical shape to the sidepanel type on your C90, and the wiring is different too so it's not as easy as just extending the wires and moving the switch!!
Cutting a hole in the C90 legshields to fi the C90ZZ is a million (AT LEAST!) times easier!! A hole cutter or a hot knife will cut through easily.
Boo
Post by Boo » Thu Jan 21, 2010 5:40 pm
I'd advise not moving your ignition switch! :o :o The front mounted switch on your C90ZZ is a different physical shape to the sidepanel type on your C90, and the wiring is different too so it's not as easy as just extending the wires and moving the switch!!
Cutting a hole in the C90 legshields to fit the C90ZZ is a million (AT LEAST!) times easier!! A hole cutter or a hot knife will cut through easily.
matt.leese
Post by matt.leese » Thu Jan 21, 2010 5:59 pm
Boo wrote:I'd advise not moving your ignition switch! :o :o The front mounted switch on your C90ZZ is a different physical shape to the sidepanel type on your C90, and the wiring is different too so it's not as easy as just extending the wires and moving the switch!!
would it still not fit in the side pannel thou? dosnt really need to bolt onto frame ;) the one on my c70zz would most certainly fit within the in the side panel but wouldnt nolt to frame due to shape. , :)
but i would still rather cut the hole in the legsheild!
