Wiring loom section needed
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
Has anyone got the short section of wiring loom for the coil on a 12 volt cub. It is item 18 in the picture. It has spade connectors on the coil end and bullets on the other end that connects to the main loom. Must be cheap. I will pay postage which should be no more than a quid normal post. It will fit in a small padded envelope.
- krazy kev
- C90Club Clown!
Re: Wiring loom section needed
Im still looking. here is a picture of a coil. its the little length of cable i need which are coloured green & black/yellow
- Pjam
- SPAMMER!
Could you not make it up with wires and connectors?
- krazy kev
- C90Club Clown!
think i will. it will be saving me postal costs as well. cheers matePjam wrote:Could you not make it up with wires and connectors?
