c70 piston needed
- verntowers
- Rides:: honda 70ish
c70 piston needed
i really need a piston and rings to fit c70 as i have one that the rings have stuck on...arse
- herrod
- Rides:: C50 cd90z 600 Rotax flat tracker.
Re: c70 piston needed
pistons are same as 90 mate unless its a zz
- verntowers
how would i tell what year the engine is as it is on its own and not attached to a bike???
cheers
cheers
- herrod
6 volt or 12volt engine?
- verntowers
not really sure how can you tell???
- verntowers
sounds daft but it is a spare engine without frame and i am a dumbass when it comes to these things... but i am learningverntowers wrote:not really sure how can you tell???
- matt.leese
6v has a round cover on the magneto cover ( left hand casing )which you can remove, which says honda on it , that is a 6 volt motor.
- verntowers
i will check tomorrow and see
- This seller has a record of poor service. BEWARE!
- Rides:: c50 c70 c90 cub 50 cub 70 cub 90
hi there vern
i have a piston for your c70 me mate
i spoke to you regarding the engine on the phone
iam sure its the 6 v is that right
M L H
M L H
- verntowers
the one in my bike is 6v and is ok but the spare engine i have bought is ...i think a 12v
