Has anybody got a Yamaha T80 Cam Chain its a long shot i know but if you do just send us a PM
Thanks Sam.
Yam t80 Cam Chain
- SamYamT80
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
Re: Yam t80 Cam Chain
is it the same pitch as a cub? if it is and the cub chain is longer you could remove some links to make the correct chain
- cruncherkid
- Rides:: CD175
What you smoking there Kev? Even if it is the correct pitch, would be UTTER madness to fabricate a camchain yourself given the speed that it runs at.....krazy kev wrote:is it the same pitch as a cub? if it is and the cub chain is longer you could remove some links to make the correct chain
Trip to/phone call to a Yamaha dealers would be a better idea, part number is 94580-25082, but i doubt they'd beat this price on Ebay for a quality DID one...
http://www.ebay.co.uk/itm/YAMAHA-T80-TO ... 2c604b8b76
- krazy kev
- C90Club Clown!
if the correct linf tool is used it should be perfectly safe to do.cruncherkid wrote:What you smoking there Kev? Even if it is the correct pitch, would be UTTER madness to fabricate a camchain yourself given the speed that it runs at.....krazy kev wrote:is it the same pitch as a cub? if it is and the cub chain is longer you could remove some links to make the correct chain
- SamYamT80
going to change the adjustment screw first and scretch the spring if that doesnt work I will be on evilbay for a chain.
