Pivoting footrest bar with rubber footpegs and sidestand.
Glenn
Rides:: Honda C90T 96 on S plate, Street Triple, R6
Post by Glenn » Wed Dec 21, 2011 3:45 pm
I am looking for a set of these because when I move my cub in and out of my shed, my stock pegs are getting caught on the front wheel of my Triumph and that is annoying.
Help please.
P.S. Its a 96 model C90.
Re: Pivoting footrest bar with rubber footpegs and sidestand
Post by wightegi » Wed Dec 21, 2011 3:51 pm
There yuo go pit bike parts are where I got my lifan from and a few other members have used them good, service and quick delivery
but it is christmas :?
http://www.pitbikeparts.co.uk/footrests ... hfais8kud5
dread
Rides:: lamb chop, vespa cutdown. italjet dragster chopper
Post by dread » Wed Dec 21, 2011 4:50 pm
i had been planning on cutting some up to make custom cub ones, my self. there is a set on ebay thumpster with out side stand for 10 plus 6 postage. ;)
Glenn
Post by Glenn » Wed Dec 21, 2011 4:51 pm
Yeah but I whant it to look stock. Apparently the CT110 has them.
dread
Post by dread » Wed Dec 21, 2011 5:00 pm
Glenn wrote:Yeah but I whant it to look stock. Apparently the CT110 has them.
yes thats exactly what i am planning cutting the ends off, and welding to the cub bar. ;) might have to drill out the centers and load a slug in there. before welding ;)
Ventura
Rides:: '91 C90, '73 ST70 & Z50, '76 TL125, '80 Bultaco 250, '16 Yam XSR900,
Post by Ventura » Thu Dec 22, 2011 7:43 pm
Glenn wrote: Image
Ive been looking at the same thing to fit to a Cub.
But from the photos it doesnt look as tho the pegs rise as high as on the stock Cub peg bar.
Can anyone say if the footpeg height ends up the same when fitting one of these Monkey/Pitbike peg bars, or will they end up lower?
Or is a better alternative to just weld pivoting footpegs to the standard bar?
Any advice would be greatly appreciated.
Cheers.
V.
dread
Post by dread » Thu Dec 22, 2011 8:44 pm
THEY ARE NOT ANY WHERE NEAR AS HI, almost flat, as i say if you really want the folding part. the best way i can think of, is to do what i posted first off, lop off both sets drill hole in the ends of all and push a slug in, then connect the ends and weld em up. :D the pit ones do not fit the Mteck pipe, and as i am going to use one that is how i am looking to go. ;)
Ventura
Post by Ventura » Thu Dec 22, 2011 10:00 pm
Cheers for the reply Dread.
Looks like I'll go with your good suggestion then. Lop 'em off and reweld onto the original bar it is then!!:)
V.
dread
Post by dread » Thu Dec 22, 2011 10:19 pm
you could do it with sleeves just as easily if not more so.
tomorrow i'll take pictue of the two side by side, you'll see the difo then ;)
Ventura
Post by Ventura » Fri Dec 23, 2011 6:47 am
Cheers Dread.
That'd be much appreciated.
Good idea on sleeving too. Would likely give more support than the small slug.
V.
