Im after the small end tip ( cone) from a cub exhaust sure on some models they rivet on? Anyway I'm after one if anyone's got an old exhaust. I'm not scared of a bit of rust. As long as its straight.
Thanks liam
Cub exhaust tip. The rivet on type
- Rides:: c90
Re: Cub exhaust tip. The rivet on type
What year and do you mean the small bore pipe that fits inside the end of the box?
On the early ones they were held in with a screw on the later 12v ones they are spot welded on gen ones and rivited on patern ones.
- Rides:: c90
It's the very end of the exhaust, the part where the smoke comes out ha, im after that small cone part at the tip. Sure some are riveted on? Or a piece that can be removed and replaced (to change baffles etc.)
- Alan CF
got a old pipe with a rusted neck if you want to collect it, the collar at the header has snapped off, but the rear end is ok,
just of J29 M1
just of J29 M1
