Wanted Generator casing.
- j-dogg119
- Rides:: 1984 Honda C90C, 1988 Tomos Disco (A3ML)
anyone got a spare generator casing they dont need for a 12v engine, it seems every engine i come across has it missing so someone must have a pile of them somewhere.....
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
Re: Wanted Generator casing.
A 6 volt version should fit your cub. The only difference is that the 6 volt version has a removable cover held on by 2 small screws so you can get to the pointsj-dogg119 wrote:anyone got a spare generator casing they dont need for a 12v engine, it seems every engine i come across has it missing so someone must have a pile of them somewhere.....
- cruncherkid
- Rides:: CD175
Sadly no if we're talking about kickstart engines, there's an extra bulge for the CDI pickup, so won't fit....also some of the later 12V (Brazil) have a prouder flywheel that the early 12V cover won't fit either, but the deep casing fits all...krazy kev wrote:A 6 volt version should fit your cub. The only difference is that the 6 volt version has a removable cover held on by 2 small screws so you can get to the points
- j-dogg119
its a kick start engine.
