Hi ,
Anyone got the above or be able to point me in the direction of a supplier ?
Mine was seized solid and was affecting the rear brake pedal so have had to cut it off , rather a 2nd hand stand if possible to go with the 'look' of the bike
Thanks Rob.
Early c70 centre stand and pivot ?
- r80rob
- Rides:: 73 c70 with c90 110, 72 MZ es250 and a r80!
- krazy kev
- C90Club Clown!
- Rides:: 12V CUB HEINZ
Re: Early c70 centre stand and pivot ?
Vauxhallsteve & Cruncherkid have recently obtained a lime green C50Z2?? that i believe might be for the scrap heap. I dont know if the stand is the same as the one you want but it should fit ok. I believe that the pin has always been the same from the 1950's onwards. They are around £10 or less new. You could get the stand off the boys and if needed they could cut it off with a bit of frame if the pin is seized (very likely) and you can use heat to remove it or soak it in diesel or plus gas for a couple days
viewtopic.php?f=13&t=7011
- r80rob
Cheers - will pop a question on the thread
