c100
- cruncherkid
- Rides:: CD175
Re: c100
Hi Rob, have got quite a lot of C100 parts, though am not sure exactly what is spare yet until the bike is getting put back together.....RobG wrote:hi, i'm looking for an engine for my 1964 C100, and a kickstart shaft as mine broke, plus any other bits anyone has as i'm in the middle of a restoration. Any help would be gratefull. thanks, rob.
Here's the project thread viewtopic.php?f=13&t=3085
Whereabouts in York are you? I'm in South Bank....York crew always on the lookout for extra riders for our days out
- Rides:: C100
Re: c100
Hi, I'm in Dunnington, my bike is comming along nicely, but I snapped the kickstart shaft one day, so I would rather try to get a decent
engine(?) if I could to swap over and repair mine later, will other engines fit? you seem to know alot more about these bikes than me.
Thanks,Rob.
Thanks,Rob.
- cruncherkid
- Rides:: CD175
Re: c100
My partner in crime Vauxhallsteve is in Dunnington! Kickstart shafts are a known weak point, whole engines are hard to come by, good ones even more so...especially with a kickstart!! To be honest, even though its a full stripdown to replace the shaft, is a relatively easy job on a pretty simple engine compared to later types. Later 6v OHC engine should go into your bike with minimal fuss, but for me it completely ruins the character of the bike being what it is and how old it is....C100's are relatively rare. Are you going to put some pictures of your bike up?RobG wrote:Hi, I'm in Dunnington, my bike is comming along nicely, but I snapped the kickstart shaft one day, so I would rather try to get a decent
Thanks,Rob.
- Rides:: c90 gold, c90 red with mags, st70, lady dax, z50r
Re: c100
where abouts in dunnington are you rob?RobG wrote:Hi, I'm in Dunnington, my bike is comming along nicely, but I snapped the kickstart shaft one day, so I would rather try to get a decent
Thanks,Rob.
- Rides:: C100
Re: c100
hi cruncherkid, thanks for the reply, your bike looked quite bad in those pics, the engine looks great, might get mine done if i'm going to have to take it apart, i want to keep it all original, do you know where can i get a kickstart shaft from?, silvers are pretty expensive! can the broken shaft be welded back together? where do you get gaskets/oils seals from? might try to get some pics on soon.
Re: c100
not far from the park then, im at the other side aspen close, yes sounds goodRobG wrote:hi vauxhallsteve, ashdale road, where are you? maybe we could meet and discuss projects?
Re: c100
we got the gaskets from ebay and all the seals from david silversRobG wrote:hi cruncherkid, thanks for the reply, your bike looked quite bad in those pics, the engine looks great, might get mine done if i'm going to have to take it apart, i want to keep it all original, do you know where can i get a kickstart shaft from?, silvers are pretty expensive! can the broken shaft be welded back together? where do you get gaskets/oils seals from? might try to get some pics on soon.
- cruncherkid
- Rides:: CD175
Re: c100
Hi again Rob, certainly wouldn't contemplate welding the shaft We've got all the necessary contacts fairly local so you can get your engine as nice as ours
This would be the recommended gasket set - Noboru are often a better fit than genuine
http://www.ebay.co.uk/itm/Honda-Cub-C10 ... 484039a569
I see Silvers do a seal kit for £7+vat+shipping now, we bought the genuine seals individually, still wasn't too dear
Let us know when you're meeting up
