DOSH WAITING... would like to find a 4 speed box,
list of numbers below to confirm you have the right box,
The ATC70 uses a 72cc OHC single with a 3 speed [73-81] or 4 speed [82-85] auto clutch transmission.
Hope this info helps you guys get to know your ATC70 a little better.
FRAME VIN NUMBERS
1973....ATC70-1000001 and up....Front fork is silver..Only offered in Daytona Orange..2 piece rear fender assembly..Flame decal on tank.
1974....ATC70-1100001 and up...Same as 1973 model mechanically......Only offered in LightScarlet Red....Rear exhaust shield with 4 holes.
The ATC70 was not produced from 1975 to the fall of 1977, when it was re-released as a 1978 model. It received many changes from the 1974 model.
1978.....ATC70-2000036 and up.....One piece rear fender....Light Scarlrt Red.....Rec Front number plate
1979.....ATC70-2100001 and up....Unchanged other than fuel tank decal
1980.....TB03-2000001 and up......Light Scarlet Red........Black number plate
1981.....JH3TB030*BC600001 and up........Fuel tank decal change.....New Passion Red Color
1982.....JH3TB030*CC700001 and up.......Receives 4 speed trasmission....Fuel tank decal change
1983.....JH3TB030*DC800006 and up......Fuel Tank decal change
1984.....JH3TB030*EC900001 and up......Fuel Tank Decal change....Seat receives a Non-pleated cover
1985.....JH3TB030*FK000001 and up......Fuel Tank decal change....Blue seat w/70 logo.....Automatic cam chain tensioner
ENGINE NUMBERS
1973.....ATC70E-1000001 and up
1974.....ATC70E-1100001 and up
NO 1975 THROUGH 1977 MODELS BUILT
1978.....ATC70E-2000007 and up
1979.....ATC70E-2100001 and up
1980.....TB03E-2000001 and up
1981.....TB03E-2600001 and up
1982.....TB03E-2700003 and up
1983.....TB03E-2800001 and up
1984.....TB03E-2900001 and up
1985.....TB03E-3000001 and up
ATC70 4 SPEED BOX 1982 ON
- Alan CF
- Alan CF
Re: ATC70 4 SPEED BOX 1982 ON
found this one, just come on, he says its a 4 speed, but wont post...
anyone in kent to collect for me
http://www.ebay.co.uk/itm/320803108125? ... 500wt_1202
- richardcole3
- Rides:: honda z50a
alan . what u upto ha ha
you building summut same as mine ? or meatier ?
like i said i reckon you need c90 bottom end , atc 4 speed box . and a z50r kick start spline ? and a 110 head and barrell and to open your cases up a little
however if youve got something else in mind all that wont help
good luck in your search ...
- richardcole3
more info :
You can get Atc 4 speed box in cub 90 cases, and fit a chinky cast barrel 50mm, put in honda rings and piston and fit e22 head, just increase your service time, or use domed piston and matched head and standard barrel . Fit heavy duty clutch springs in standard semi clutch. job done .
Stock C90 barrel can be bored out to 50mm takeing it to 98cc.
ATC70/S65 and later Z50 and i think crf50 4 speed gearbox can be made to fit ok you just need the right kickstart for the ATC box.
you can also fit CT70 and SS50 4 speed boxes but the kickstart and first gear can go if fitted to bigger engines.
- Alan CF
back up for sale no reason why it fell through, he still wont post it, his loss
dont you just love it when sh1t happens to some people
http://www.ebay.co.uk/itm/320808242725? ... 500wt_1202
- Alan CF
