inlet manifold.
- dread
inlet manifold.
as per the headline Ta. its for a pit bike engine. so it don't need to be inline to reach original air box. can be side mouthed. thanks.
- Lister
- Rides:: Honda c90 1989, Honda c90 dragster, Honda C90 1990. Honda c70, Honda c50
Re: inlet manifold.
i dont have any around but seen this on ebay carnt be bad for £3.50
http://www.ebay.co.uk/itm/pit-bike-carb ... 3a6c193009
Lister
Lister
- Cerberus73
Re: inlet manifold.
dread i got heaps, what size u needing, for what size of motor, cover the post n ya can has one.. u need the plastic spacer as well?
- dread
Re: inlet manifold.
ok cheers boys. was hoping my mikuni would have turned up today. its off a Suberbyke RMR 125 trialy thing, now speaking with a few folks, it seems the 26 is a 22, but it could also be a 26, so untill it comes. and measure it, i am in the dark a bit mesen. knowing my bleeding luck, it will turn out to be 19, and of no use to me.
http://www.ebay.co.uk/itm/130593685977? ... 1439.l2649
so i shall upon its arival, post up the sizes. thanks.
- dread
Re: inlet manifold.
tizz a reworked big bor fat headed 125 posted a pic of the carb i bought. but i only have the bar info on the auction to go on as yet mesen.Cerberus73 wrote:dread i got heaps, what size u needing, for what size of motor, cover the post n ya can has one.. u need the plastic spacer as well?
- Cerberus73
Re: inlet manifold.
Ah right most the carb manifolds i have are off 110cc pit bike engines, think the carbs on some of them are 26mm jobs, so if your carb is 24-26mm should work just fine. i will give a couple a clean up and get the vernier out to check dimensions for ya.
- Cerberus73
Re: inlet manifold.
ok got hold of largest one i have, its 24mm bore so will be fine for 24mm carb, its the side angled one, so fine for a chop but no use on a standard cub, bores nice and smooth compared to some of them I've seen. and the silver paint on it is flaky, so could do with a repaint. but its yours if you want it along with its plastic spacer piece. just gimme your address in a pm and cover my postage, can't see it being more than about 3 or 4 quid to post it, probably less. paypal is fine for the postage. will let you know how much it is once i send it.
- dread
Re: inlet manifold.
right the porting on the head is lapped in 26.5 down to 25. so should be able to match that i should think. still waiting on the bleedin carb.
- Cerberus73
Re: inlet manifold.
well your welcome to it. heres a pic of the said parts. gave it a clean up for you.
- dread
Re: inlet manifold.
ta pal, as per p/ms send it up, wee the coil, and i'll ping you some paypal. will need your account email remember. have sent my address to you.
