,,,would one source a repair kit similar tothis (I tend not to "do" ebay, as it seems to be populated and indeed,run,by shysters)
where,,,
- herrod
- Rides:: C50 cd90z 600 Rotax flat tracker.
Re: where,,,
I think wemoto do them,I'd send you a link but I'm using the internet on my phone.
Re: where,,,
link to above. http://www.wemoto.com/bikes/Honda/C_90_ ... epair_Kit/
you can buy on line or phone them up I have 2 bikes and have the right year and model of each bookmarked on my computer so if I need any thing I can look there. The link is to a 12 volt model .
- Sw4mpy
- Rides:: ,'88 C90G x 2
Re: where,,,
cheers fellas (now compiling a list ) ,,,is there a difference between the 12 and 6volts then ? ,,as far as the front forks go ? (note to self, gen up on model differences)
Re: where,,,
for your 89 model same as the one in the link 12 v 10mm and 6 v 12mm spindle.Sw4mpy wrote:cheers fellas (now compiling a list ) ,,,is there a difference between the 12 and 6volts then ? ,,as far as the front forks go ? (note to self, gen up on model differences)
