Needed Carb for 1986 cub 90e
- Deano -Chav- Notts
- Rides:: The "CHAV" machine of course !
Re: Needed Carb for 1986 cub 90e
Sod it .!! while i'm waiting for the rain to stop ....
i'm gonna whip the tank off ...& make dure everything is nice & clean on the inside too
Yeah I give 'em the Newt special treatment, I sand blast them with fine kiln dried sand, brings 'em up a treat!deano77 wrote:Well ...Carb is on fitted c/w heat spacer.........gotta test her when this bloody rain lets up a bit. ....
she starts ok ..lol
changing back to a 15T sprocket too ...
I'll keep you all posted....
thanks again newt .......(carb is nice & shiny..lol)
See the showers here:
http://www.meteox.com/gmapstatic.aspx?z ... =208&y=190
[/Right i have drained the tank , I have threaded a wire right through The fuel line and looked through it ,.
seems in good nick .
There we're quite a few bits in the bottom of the tank so swilled it out several times with petrol .....
now thats all cleaned put all back together and flushed petrol through carb even when i filled tank out of can i used a home made filter .
Took 16T off put original back on then cleaned spark plug ...so ....
fingers crossed !!b]
- Rides:: Red C90.
You're certainly getting around deano, over on the other site too. But you can't get away from them. They'll chase you up over here and still tell you to put a new fuel pipe on.
Ha-ha well spotted leiba......but then again could be someone else with the exact same problem that ole clich'e of there is always someone else doing the exactly the same as you at the same time somewhere in the world..!!!..
But nahhh fuel pipe shopping tomorrow it is !!...lol
been out on her just to make sure nothing drops off etc .....& not a wiff of a hiss "pop" or backfire so think my old carb was maybe sucking air in
FILTER Deano FILTER!!!!
Hi folks
sorry not been on ..had bloody car trouble so been fixing that to stop the missus from moaning ..i've not fitted the filter or pipe as yet but as i have been running about picking parts up she has not skipped a beat .....
just need to test now on a long run .......
Fuzz wrote:After youve fitted the pipe & FILTER !!!!
BRAVO OLD CHAP!!!!
VERY WELL SAID, WHAT!
Ha-ha .....thats all i need ...pushy ...step - thru riders .. ....
Working around bloody boxes too!!....as we are moving on saturday .! ...
