Wanted: 2002 C90M electric start footpegs.
- c70
- Rides:: c90m, c50, cm91
Previous owner has fitted off road type footpegs with a straight bar along with pit bike exhaust. I'm putting back to standard so got a normal exhaust to go on but current aftermarket footpegs are in the way, so looking for standard electric start footpegs, I've no centre stand either so would require side stand lug, ideally with side stand and rubbers but not essential.
I'm in West Yorkshire, can collect if local or happy to do via bank transfer and courier.
- c70
Re: Wanted: 2002 C90M electric start footpegs.
Managed to find and buy some after searching the forum a bit.
Part Number: 50610-GT0-700
Sounds good! Please could you post the result when you've fitted them?
Been searching for years for a new set for my C90MG and had a couple of false starts with ones advertised as fitting so ended up using heat and a large hammer, they're still not perfect though.
Noticed they are available from Webike for £30.56 at the mo including Airmail!
- c70
Still waiting on CMSNL for them to be delivered!!
Next Friday so I'm told after raising support ticket. Currently no footpegs and missed out on some lovely riding opportunities! Will update once they're here.
Indeed, as said, wonderful if you could post on here the outcome, when fitted, of your footpeg bar.
The question of availability and sourcing of the electric start or 'M' footpeg bar, often crops up on this forum.
Andy.
Andy.
I'm ready to push the button on the Webike offering. Still at £31 inclusive so below the import duty threshold/other faff. The racks I bought turned up in 9 days.Devon general andy wrote: ↑Fri Nov 10, 2023 2:22 pmIndeed, as said, wonderful if you could post on here the outcome, when fitted, of your footpeg bar.
Andy.
- c70
Had to cancel CMSNL order as they kept extending dispatch date, ended up at 24th December! I have just bought same part number on webike, only downside is there's no picture of the item on webike but will confirm once received.
Sounds good. I have an idea that there is some sort of tie up Webike/CMSNL. I've seen items on Webike that when you click on them it refers to CMSNL.
Or did I dream that?
- c70
Can confirm footpegs fit electric start c90, fast delivery from webike, use part number above.
