Evening folks,
1976 6v c90
Thanks in advance if anyone can help me.
I'm after a r/h indicator switch handlebar unit, it's the one with the locating bit on one side and a rim on the other. Mirror threaded hole, brake lever mount without front brake light hole, 3 wires.
I do have one but upon taking it apart the square brass connector that goes along with the small spring to make contact with the wiring is missing,if anyone has one of these small square brass contact this would also do me.
Early 6V R/H indicator switch
- Rides:: BSA
