Looking for coil with condenser
- Rides:: Ducati 916 Honda Fireblade C90 cub
Hi new to this .. I have a Honda 1980 C90 and am trying to locate coil pack with condenser. Appreciate your help .
- Rides:: c90 z2 (1978)
Re: Looking for coil with condenser
David Silvers do a reproduction 6v coil/condenser for the 6v C90s, but are currently out of stock - worth giving them a call if you aren't in a hurry.
As you have probably found out some of the coils advertised for the 6v C90 are really for cubs that have AC based ignition systems and won't work on the battery ignition used on the C90Z (and earlier) models.
The original coil was a TEC FL801 - apparently they rarely go wrong, so might be worth keeping an eye on ebay.
