1976 keihin carb
Biglav
Rides:: C90
1976 keihin carb
Post by Biglav » Wed Aug 16, 2023 8:09 am
Need a keihan carb for a 1976 c90 6v
Manual choke ie no cable, twin outlet fuel tap on right side as sat on the bike.
Any help appreciated.
Peter.
Reason: corrected spelling (because it might be better for searching)
Biglav
Rides:: C90
Re: 1976 keihan carb
Post by Biglav » Fri Aug 18, 2023 8:48 am
Think it should be a pb25a with a manual choke.
nabs
Rides:: c90 z2 (1978)
Post by nabs » Fri Aug 18, 2023 1:59 pm
according to the manual the earlier c90s used a PW20H. In any case I don't see why the PB25A (which was fitted to Z2 and ZZ model) wouldn't work - you'd need to modify the choke lever though as it is cable operated on the Z models
This is assuming you can find one, as they hardly ever come up. I have a partial PB25A one somewhere if you are desperate but I've no idea what state it is in (I bought it for parts). I'd hang on and see if someone here has a complete one though, if I were you :)
Biglav
Rides:: C90
Post by Biglav » Fri Aug 18, 2023 2:26 pm
Thanks for reply and info, will hopefully find a complete correct carb. If I can't source one I will have to mod something up.
Thanks for taking time to reply.
Peter
Biglav
Rides:: C90
Post by Biglav » Mon Aug 21, 2023 7:32 am
Still looking for a carb for a1976 c90 keihin PW20H
This is the only part I need to complete this project.
Peter.
