That's a right hand one i think
The left hand is product number: 50306033010 and currently unavailable.
They are not interchangeable.
Assuming Left is as sitting on the bike not looking at it from the front, it's happened before
Also the photo on CMSNL shows what appears to be a cast Aluminium one not pressed steel.
An improvement if you can get them but i've not seen them on UK cubs.
C90 6v top shock bracket
- Rides:: C90 CBR600 PE175
- Rides:: C90
Re: C90 6v top shock bracket
The shock bracket on csmnl diagram is item 6 left side.
Someone out there surely has a usable bracket sat on a shelf that's surplus to requirement.
Peter.
Peter.
As a stand in until one turns up
If you know a welder/ fabricator or machinist you could probably knock something up with a bit of tube welded to some angle iron or bar steel.
I don't think anyone takes them off unless they are painting the frame otherwise they get scrapped along with the frame.
i did see some on ebay a good few years ago but the seller wanted 50 quid for them and they were not much better than the ones in the photo i uploaded.
- Rides:: C90
That's definitely an option if one does not turn up.
Peter.
Peter.
- Rides:: C90
Hi.
Ordered a pair from USA, bit more than I wanted to pay but saves a lot of messing about making one.
Thanks to everyone that's been in touch.
Peter.
Peter.
