Sidestand
Biglav
Rides:: C90
Sidestand
Post by Biglav » Mon Jul 03, 2023 9:18 am
Hi.
Looking for a set of footrests with a sidestand for cub90 electric start.
Peter.
Re: Sidestand
Post by bikerbaker » Mon Jul 03, 2023 10:12 am
Hopefully someone will come up with a used set, these are like hens teeth nowadays as people were using them for Lifan engine swaps. I searched for ages for a set for my C90MG as the originals were very bent.
Some vendors (including Wemoto and MotoMania) were selling bars that allegedly fitted ES bikes, they did but the bar passed under the brake pedal and trapped it fast, (bottom set on the pic).
I eventually solved my problem by multiple beatings of the original set. The non fitting set has been passed on to someone who is cutting the sidestand tab off to weld to a late 12 volt bike. Maybe an option for you if you can source a set of bars with stand used to butcher?
Biglav
Rides:: C90
Re: Sidestand
Post by Biglav » Mon Jul 03, 2023 11:13 am
Thanks for the info.
Hopefully someone might have a set that fit.
Might have to mod but would be better if somebody has a set, would save a lot of trial and error messing about.
Pete.
Bobby90
Rides:: Honda c90
Re: Sidestand
Post by Bobby90 » Sat Jul 08, 2023 12:50 pm
I found two separate parts, then ordered a new safety rubber piece for the side stand (I wanted the safety rubber piece version). I got mine from someone selling a lot of parts and thankfully they were willing to split and had the footrest. The side stand I wanted came from another person, well used but cleaned up, painted, looks very nice.
Just surprised how much it leans, but is actually correct amount and prefer the side stand on soft ground and the rubber and also carry a plastic base to lean the bike on.
Biglav
Rides:: C90
Re: Sidestand
Post by Biglav » Tue Jul 11, 2023 6:49 pm
Thanks for replying.
Looks like I will have to make a side stand, just takes time and a little patience.
Peter.
