as title
Genuine c90 hubs wanted
thanks Ben
WANTED Hubs
- Rides:: c90, ktm 990 superduke
Re: WANTED Hubs
There is more than one type so we need to know the year.
Re: WANTED Hubs
Yea, year of particular bike, assuming original wheels?
You can confirm aswell by the brake backplates fitted ( speedo fitting etc). The brake plates and the hubs need to match, or the plates won't fit properly or the shoes won't work well on the steel drum ring. There were quite a few changes over the years.
Are your ones no good for rebuild?
A bit more info and we should be able to help you out or at least you'll know what to order.
Hope this helps, cheers Andy.
Re: WANTED Hubs
Moved to WANTED section
