Wanted Foot pegs
- Rides:: Honda C90
Wanted Foot pegs
Looking for some foot pegs that incorporate the centre stand in the same bracket
Its for an Early (1971) Honda ST, the foot pegs have a bracket welded on for the stand not like newer ones that are on the frame
Re: Wanted Foot pegs
CSMNL only list the ST90 is yours an ST70 David silver have nothing in the footpeg way.
The ST 90 trailsport was introduced in 1973 and none of them had a center stand ,side stand only. Have you got a photo of the bike and the beginning of the frame number.
Photos have to be hosted elsewhere, a lot of us use postimage.
- steveST100
The ST70 in 6v dont know about the 12v ones, had a center stand as part of it.
If worn like some of the oens i have had in the past, i had welded large washers on both sides to build it up and just took a bit off the stand to make it fit.
Also had a longer stand pin made to go over the extra thickness of the washers.
Think you may need to use the Cub stand if you want to fit this type of footrest/stand on the Cub as it has bigger wheels and the stand may be too short. Will have to have a check in the garage on the stand on my st70 with a Cub stand.
- Rides:: Honda C90
Thanks thats the very one. I was going to weld a washer to it but the tube that goes through the stand part is seized solid so might be easier to find a stand with pegs?
- Rides:: Honda C90
Frame number starts ST70-137 Can you date it from the frame number?wightegi wrote: ↑Tue Nov 15, 2022 11:01 pmCSMNL only list the ST90 is yours an ST70 David silver have nothing in the footpeg way.
I can find ST70-140840 1972 so yours is a bit earlier .
- Rides:: Honda C90
I use this ...https://www.4-stroke.net/become-a-member.html takes a bit of looking , you need page 24 down on the Honda frame number database.
- Rides:: Honda C90
Thanks that will keep me amused for hours!wightegi wrote: ↑Thu Nov 17, 2022 11:15 amI use this ...https://www.4-stroke.net/become-a-member.html takes a bit of looking , you need page 24 down on the Honda frame number database.
CSMNL do list the ST70 in their minibike section and list the footpegs https://www.cmsnl.com/honda-st70-dax-en ... 11098710b/ But not available now
