front wheel 10mm
bart
Rides:: ST70, cg125, efi 500, Terrot etd, CM200 and Fantic tx250
front wheel 10mm
Post by bart » Sun Aug 21, 2022 7:28 pm
Does anyone have a good condition front wheel they would sell ? It`s for a CD90z, as far as i can tell it`s same as c70 and some c90`s, 10mm spindle, it would need to be reversed in forks but they look the same in pictures, if there is one available photos so I can compare with mine wold be useful, pm me if you have one please, I have asked on forum which wheels may fit but no response, thanks
Devon general andy
Re: front wheel 10mm
Post by Devon general andy » Sun Aug 21, 2022 9:30 pm
Hi, I don't know any technical specifications about CD90z's. Just thought I'd say from the start!
All I can say is the the C90 Cubs from maybe 1983 /4 onwards ( not 100% certain of exact date ) , have 10mm spindles (axles) with 6300 bearings.
The earlier C90s have 12mm spindles.
Even at this late time the C90 hubs changed a few times and really changed approx '92 / '93.
Even with the late Cubs it's best to get a matching wheel and brake plate because most are not interchangeable!
Some other member on here will probably give you some more info on C70s etc.
Also the later cubs have a pronounced channel on the brake plate for the large lug (on the right leading link arm) to slide into. The earlier ones had a torque arm set up to stop the plate turning when brakes applied.
Sorry I can't give you more advice.
Good luck in your search.
Cheers Andy.
bart
Post by bart » Mon Aug 22, 2022 4:34 pm
Thanks Andy, as far as I can tell any 17" /10mm spindle wheel will work as long as I use my brake plate... so I will try to find one, cheers
