12v c90 front rack
culfy
12v c90 front rack
Post by culfy » Thu Aug 18, 2022 12:54 pm
As in the title I’m looking for a c90 12v front rack for a square headlight model, cheers Ian.
Devon general andy
Re: 12v c90 front rack
Post by Devon general andy » Thu Aug 18, 2022 3:28 pm
Hi Ian, if you type in to google or whatever:-
81100 - GK4 - 760
That will bring up some photos of the Honda rack that I know will go on at least an '86 onwards Cub. Probably the earlier aswell but cannot confirm!
There's suppliers on there aswell but your local dealer can probably order for you?
Anyway, that's the part. You need a tubed spacer and longer bolt for the main fork centre fixing! The side legs fix to the small threads in the side of the forks. If there's nothing screwed in there now (reflectors etc), may be worth trying a bolt with oil or running a tap in to them to clean them up? Don't use to much force... they're only like 'thread nut' fittings.
Hope this helps, cheers Andy.
