I’m looking for this unit:
Thank you
Honda cub lac parking brake lever
- Rides:: honda c50, 90 atc monkeys
- steveST100
Re: Honda cub lac parking brake lever
The switch in your photos is from a c50lae the 12v square headlight model and not the c50lac 12v round headlight which has thinner bars.
If you want it for a custom build with aftermarket bars you need the type in your photos from the c50lae.
This is the two types with the c50lac on the left and c50lae on right,note the lae one has had part of it cut off as i didnt want the locking button bit on there.
They are pretty useless as a clutch lever ,a pit bike one can fit if you extend the bar by about 1 inch.
Didn't know there are more types of parking brake levers.
LAE or LAC doesn't mather witch type. as long as it's a parking brake unit. i'll make it fit
I'm not going to use it as a clutch lever. It's for my ATC90 so i can park it on hills
Thank you.
Thank you.
Leave it in gear.
Good idea, but that only works when the engine isn't running.
Found one,
thank you
thank you
