Wanted 86 c90m (electric start) flywheel cover
- Rides:: 86 c90
Wanted 86 c90m (electric start) flywheel cover. Possible trade for 88+ one
- Rides:: ST50
Re: Wanted 86 c90m (electric start) flywheel cover
I'm curious as to the differences and why you want to swap?zandersconrad wrote: ↑Mon Feb 05, 2018 10:14 pmWanted 86 c90m (electric start) flywheel cover. Possible trade for 88+ one
- Rides:: 86 c90
The 88+ c90s use a differant stator to the one i require and is mounted differantly and plug onto the using differant connectors etc. Which i found out after i had bought it was hoping somone had made a simular mistake but the other way round
- Rides:: ST50
I thought that may be the case, I'd happily swap my older version for your newer cover, stator and flywheel. but I'd have to convert it back to bullets for you, so you'll probably prefer to convert yours to bullets instead, although I'm not sure if your older flywheel will work on the new stator if you're only fitting the cover and stator to your older engine and bike.zandersconrad wrote: ↑Tue Feb 06, 2018 7:20 pmThe 88+ c90s use a differant stator to the one i require and is mounted differantly and plug onto the using differant connectors etc. Which i found out after i had bought it was hoping somone had made a simular mistake but the other way round
- Rides:: 86 c90
unfortunately i only have the flywheel cover it didnt come with the stator or flywheel as i already had the bits that were designed for my engine. if you would like to private message me hopefully we can sort out some kind of deal...
- Rides:: ST50
I'm surprised the cover is also different, I'm not doubting you. Sorry no deal to be had, I don't want to end up in your current position.zandersconrad wrote: ↑Thu Feb 08, 2018 8:51 amunfortunately i only have the flywheel cover it didnt come with the stator or flywheel as i already had the bits that were designed for my engine. if you would like to private message me hopefully we can sort out some kind of deal...
- steveST100
Hi If you could post photos of the two types when you have them it may help others.zandersconrad wrote: ↑Tue Feb 06, 2018 7:20 pmThe 88+ c90s use a differant stator to the one i require and is mounted differantly and plug onto the using differant connectors etc. Which i found out after i had bought it was hoping somone had made a simular mistake but the other way round
- Rides:: c90 gold, c90 red with mags, st70, lady dax, z50r
ive got a flywheel cover complete with electric and flywheel, if you still need one
