Does anyone have for sale a rear swing arm for a low headlight C100 or C110 (same part numbers on CMSNL)?
If not could someone advise on resurfacing my original. It looks like the drive hub has gauged a circular depression - the lower rear chain guard bracket is about to drop off! See pic below.
I have brazing facilities so could fill the gap but not sure if this would be strong enough - any views?
Wanted C100/C110 rear swing arm
- Rides:: 1978 C90 6v, 1964 C110, 1964 CA72
Re: Wanted C100/C110 rear swing arm
A competent welder could easily build that up & grind it smooth like new & it probably wouldn`t take more than a few minutes.
It depends if you can get a better one easily or not or if the rest of the arm is sound really
