Massive stab in the dark!!
Asking for a friend.
Honda 90 S - Engine / Bottom End
- Rides:: HONDA SUZUKI
Re: Honda 90 S - Engine / Bottom End
if its a 6 volter i got plenty of cyl heads one reconditioned
Thanks but top end is not needed!
I cant help with an engine (I'm is Aus) but assuming you need a "3 mounting bolt" engine there are other options depending on what you need.
There are different cases on S90 engine depending on the year. This link shows some of the differences.
http://s90partspuzzler.blogspot.com.au/ ... -late.html
One other item to look at.
I have a large collection of 90/110/125 engines and Have bought a few cheap that have cracks in the left side crank case between the bearings, this I believe is due to a rear chain jamming itself in the casing and ultimately cracking the case. These are both in manual and semi auto.
Thanks Gazza!
