as stated above in good working order please,
thanks ross
6v engine 70/90
- herrod
- Rides:: C50 cd90z 600 Rotax flat tracker.
- Boo
Re: 6v engine 70/90
Bear in mind the 6v 70 and 6v 90 engines are completely different castings and won't fit in each others bikes without drastic mods.. The electrical systems are totally different too.
Just so's your not wasting your time on a non-suitable engine!
Re: 6v engine 70/90
This is a C70 C90 (12v) type engine.
As you can see , quite a small engine with NO points housing on the cam shaft
Unlike the 6volter C90 , Larger engine & points housing on the cam.
Re: 6v engine 70/90
- herrod
Re: 6v engine 70/90
ah right i thought there was a c90 6v,in that case im after a 6v 70
cheers
cheers
