Silly little things
- Pjam
- SPAMMER!
Silly little things
I'm almost embarrassed to ask cus there so small but I need spacers+bolts for legshield (C90ZZ) and blanking discs for the forks? anyone.
- matt.leese
Re: Silly little things
Pjam wrote:I'm almost embarrassed to ask cus there so small but I need spacers+bolts for legshield (C90ZZ) and blanking discs for the forks? anyone.
make the leg shield spacers out of a flat piece of stainless about 3/4 wide 10mm thick , bent over at each end, i bought some from cms think they were £7 each and the bolts are £10 for both! cheaper to make them.
- Pjam
- SPAMMER!
I 'll try that matt, it's a good solution, not one I'd have come up with!
I got some from Orwell's for a 12 volter, only about £2.80 each....
- Pjam
- SPAMMER!
Could there be one part in common, please!Newtsalad wrote:I got some from Orwell's for a 12 volter, only about £2.80 each....
No, I do believe they are all different!
- Rides:: Red C90.
I spotted this last night.
http://cgi.ebay.co.uk/HONDA-C90-C70-C50 ... 27afbef6b9
I need one too. I have one but I've no idea where it came from or where the other one is.
A guy in the pub gave me a long piece of threaded bolt(?) and some nuts. I was going to cut it to length find a bit of suitable tubing and with a couple of washers and nut, use that to make my own.
- Pjam
- SPAMMER!
Great spot Leiba Are you bidding? I don't want to bid against you! I was going with Matts DIY solution but I'd go for that one if your not?leiba wrote:I spotted this last night.
Very elegant avatar by way
- Rides:: Red C90.
No, you can have it. Personally I think the P&P are a bit too much. I know it's only £1.50 but I still think he's upping the price that way.
But didn't you want two?
- Pjam
- SPAMMER!
Actually one would do it! Thanks Leiba, it will be between me and about 500 hundred others then
